Fluctuating idle on new intake manifold.
Old Jun 16, 2008 | 10:28 AM
dem0nk1d's Avatar
Default Fluctuating idle on new intake manifold.
So over the weekend I found out that my Z6 intake manifold cracked on the water port of the flange. Well to make a long story short I got a cheap 92-95 Dx manifold swapped over all components. I decided while the manifold was off I could bypass the coolant lines. The way I did this, is capped all of the smaller coolant lines with rubber nipples. So the car stars up fine, but doesn’t hold an idle. I thought once all the old coolant lines are capped you should be good to go, you should be solid. I guess not… I’m I missing to do something?
I'm going to try this also when i get home....
http://92lude.com/idle_air_control_bypass_mod.htm
could be the issue....
Old Jun 16, 2008 | 10:32 AM
A BOOSTED CRX's Avatar
Default Re: Fluctuating idle on new intake manifold. (dem0nk1d)
is it a vacuum leak? just check your vacuum lines
Old Jun 16, 2008 | 11:38 AM
dem0nk1d's Avatar
stopping at honda after work to get a new throttle body gasket. also could be an issue with the make shift o-ring that's need with the IACV on the backside of the manifold.
Old Jun 16, 2008 | 11:44 AM
dem0nk1d's Avatar
i should go buy some carb cleaner to find if i have a leak. carb cleaner finds leaks like crazy.
Old Jun 16, 2008 | 07:06 PM
dem0nk1d's Avatar
fix by putting duct tape over the big hole in the throttlebody
https://honda-tech.com/zerothread?id=2153910 <--FTW!
Vagitarian
23
Oct 21, 2012 08:27 PM
thead
Aug 31, 2012 07:47 PM
squirtinsnake
Jan 25, 2005 08:29 PM
