temp. gauge ground??
Can someone please tell me the ground for the temp. gauge. My temp. gauge jumps around everywhere when I'm driving it. I know it's not overheating cuz i pretty much replaced everything on the whole car. I've checked the grounds under the hood like the valve cover to the frame, t-stat ground the the battery to the tranny. Any other grounds that I'm missing. It's a '91 std with a Y8 mini-me swap if that matters. Thanks
I just took the center bezel out that goes around the stereo and temp. controls. There is a black wire that is screwed to the metal right next to the A/C button but the other end of the wire is cut. Is that a ground for anything or do you think it was a ground for a stereo. There is no stereo in there right now. If it is for something important where does the other end go?
Boost Junkie 83
Apr 28, 2007 05:41 PM
