water leak 98 accord lx
Old Jun 16, 2008 | 07:36 AM
Desiss's Avatar
Default water leak 98 accord lx
not sure if this is normal, but lately i've noticing alot of water, if im sitting in the car with the ac for like 2 mins, then get out. I live in florida, and it's very hot here. I checked the radiator coolant and its pretty much full, so no leaks there. Yesterday the engine started to heat up a little bit, the needle got half way, so im not sure where the leak could be coming from.
Old Jun 16, 2008 | 08:02 AM
Heat's Avatar
Default Re: water leak 98 accord lx (Desiss)
If you are sitting with the AC off, is there water?
Old Jun 17, 2008 | 02:36 PM
bymike's Avatar
check if it is coming from the water pump ,this year had an water pump o ring (gasket) problem. The dealer carries a gasket that they remanufactured and corrected the problem
ps water is supposed to drip of the condencer when the ac is running
patoloco008
Aug 29, 2013 11:42 AM
thekid2390
Jun 30, 2013 12:15 PM
DACteg
Jul 27, 2010 11:04 AM
SamC
Jul 29, 2009 09:20 PM
osseb
Honda S2000
Aug 9, 2008 09:10 PM
