flywheel resurface: how many times can it be done
I am not sure of a 'measurement', however in my experience most machine shops will be able to tell you if it can be resurfaced or not from looking at it. They do it so often, they have a pretty good feel. Honestly, sometimes if you are unsure, a decent flywheel is not that expensive anyway, and its going to cost anywhere from $30-50 anyway to resurface it.
The only spec honda gives for a flywheel is a runout limit.
If over .006" of clutch surface runout then it is out of spec for machining.
mike93boost
Jul 3, 2006 08:42 PM
immalooser
Oct 18, 2005 08:08 PM
