Help! Morning Car Smoke?
Okay so my set up is t3t4 garett, ARP HEAD STUDS, Test pipe 2000 si, stock motor, 550cc tt injectors with chiped p28...7psi of boost..150psi in each cyl. I leak No oil, i have a oil pressure gauge an my pressure is consistant. I baby sit my car an check it out every day while i let it run to cool down befor dinner.
So, every morning, i wake up, start my car, let it warm up till its all the way warm., then when i pull out of my drive way, my car blows blueish/white smoke then it stops. Like 100% stops.
My turbo is NEW, i had it on my car with no WG spring for like 2 months befor i ever got into boost. My oil line has a restrictor on it so...... i unno...
I my self think its condensation cause i have a Huge inter cooler. Cause after i let it warm up, i will hit my 2 step, an water will come out my exhaust all over the pavement.
Im using 20/50wt oil in my motor, i was using 10 40 but i went thiker cause i thought i was leaking oil into my motor from my turbo. But maybe not?
I need your guys thoughts an OP cause my car never smokes after a block. I really think its condensation.......
thanks for reading, any help or sugestions would be great!
Modified by riddlinkid1986 at 6:37 AM 6/16/2008
my car dose not, Humm, if my head gasket is blown would'nt my compression be off? cause im pretty dead on 150psi give or take 3psi
99jdem18L
May 18, 2005 05:30 PM
SteveeeO
12
Mar 31, 2003 04:59 PM
