Using Mugen gasket with milled head?
Would it be a good ideal to use a Mugen 1 layer gasket with a .020 milled head?
Im thinking the cr would be around 11.1-3. Anyone have now and would like to comment? Any problems with it?
Mugens are 2 layer
"METAL HEAD GASKET
A two-layer construction is used instead of the normal three-layer gasket plate construction, and a rib (+0.07mm) is laser-welded close to the plate surface sleeve to prevent blowout occurring at high compression. This head gasket raises the compression ratio by 0.4 points. Construction is entirely of stainless steel."
[Modified by Phat Bastard, 2:51 PM 7/17/2002]
"METAL HEAD GASKET
Assuming your using a b18c5, stock pistons and such, and the head is at .020 off and a 2 layer gasket, your comp. ratio should be around
11.47 : 1
11.47 : 1
Spoon sells a stock head gasket with the middle layer removed.
Toda sells metal head gaskets in three sizes (0.6mm, 0.8mm, 1.0mm).
Stock head gasket is 0.6mm.
11.47 : 1
11.47 : 1
