Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
adjust coilovers
Old Jun 16, 2008 | 02:13 AM
theciv's Avatar
Default adjust coilovers
is the spring supposed to be able to move around freely when the car is raised? For example, when i adjusted the coilovers, i loosened the (2)perches and rotated them down and tightened them while the spring could move up and down. is this wrong?
am i supposed to keep the springs up where the spring is firm against the top hat? and then twist the whole bottom portion upward making the part with the threads move downward into the bottom of the strut?
im sorry im so confusing but i know SOMEBODY has to know what i'm talking about.
...and is this why i'm losing alot of my performance as far as the suspension goes because my friend has coilovers and are way different in terms of handling and roughness then mine. (*me knowing he has totally different spring rates)
Old Jun 18, 2008 | 11:55 AM
DynastyRacer22's Avatar
if its just the sleeve coilovers then yea its supose to did they gave you any rubber O rings? you can use those to keep em from moven around its not necessary tho
Old Jun 18, 2008 | 12:13 PM
funz0rzies's Avatar
What kind of coilovers? It all depends. Some brands you can preload the springs and others they seat properly when the car is on the ground
Old Jun 18, 2008 | 06:46 PM
theciv's Avatar
Default Re: (funz0rzies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynastyRacer22 &raquo;</TD></TR><TR><TD CLASS="quote">if its just the sleeve coilovers then yea its supose to did they gave you any rubber O rings? you can use those to keep em from moven around its not necessary tho</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funz0rzies &raquo;</TD></TR><TR><TD CLASS="quote">What kind of coilovers? It all depends. Some brands you can preload the springs and others they seat properly when the car is on the ground</TD></TR></TABLE>
Megan Racing Full coilovers.
i've fixed it. thanks guys. i was being stupid. my shock wasnt loading...at all. so i fixed it, the rears are still giving me trouble but **** im tired.
I also jus got rid of the 205/40r16 tires and replaced them with Toyo Proxes4 205/50r16
SOOO much better.
Old Jun 18, 2008 | 07:19 PM
Harlowe's Avatar
Function>Fashion
You should keep the springs tight against the top hat.
Old Jun 18, 2008 | 08:10 PM
skipbarber's Avatar
helper springs always help
Old Jun 18, 2008 | 08:55 PM
post some pics man! lol your car looks good i want to see it on some megan tho
eh2..765
Suspension & Brakes
Jun 15, 2005 12:15 PM
Aphrodavid
Nov 27, 2002 12:42 PM
Brett
Nov 23, 2002 12:41 AM
BrandonClaps
25
Aug 11, 2002 10:47 PM
allmotorEG-SI
Oct 16, 2001 05:41 PM
