92 accord rear brakes
Old Jun 15, 2008 | 04:13 PM
true-elements's Avatar
Default 92 accord rear brakes
i have a 92 lx with rear drums.. i just purschased a set of rear discs i need to know is it a very hard swap to do and how do i go about removing the old rotors.
Old Jun 15, 2008 | 05:51 PM
thabao's Avatar
Default Re: 92 accord rear brakes (true-elements)
do you have just the rotors or do you have everything you need to do a rear drum to disc conversion? you cant just pop off your drums and slap on rotors if that what your thinking.
theres a right up in the FAQ if you need answers
Old Jun 15, 2008 | 06:48 PM
Default Re: 92 accord rear brakes (thabao)
i have the whole setup everyting..
Old Jun 15, 2008 | 06:53 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by true-elements &raquo;</TD></TR><TR><TD CLASS="quote">i have the whole setup everyting..</TD></TR></TABLE>
If you have everything then you should have no problem removing the old parts that need to be removed and then reinstalling the new parts.
Old Jun 15, 2008 | 07:15 PM
Default Re: 92 accord rear brakes (Hawkze_2.3)
ok
i know but what i need to know is how do i change the rotor i need to put on a new rotor will i have to get them pressed out or how will i change...
Old Jun 15, 2008 | 07:23 PM
thabao's Avatar
please read this write up
you might find what you need, alot of answer can be found in the FAQ stickie or searching
http://www.accordinglydone.com...=2056
19Accord97
Jun 3, 2009 08:36 AM
hb_guy
Mar 3, 2007 06:50 AM
drSquish
Jun 14, 2006 10:27 AM
mykg4orce
Mar 27, 2005 08:46 PM
greasemonkeyeddie
Oct 24, 2003 06:50 AM
