Greg Dupree's 9 sec pass no nitrous, Nissan 300zx twin turbo
Video:
http://www.askthedrunk.com/seedyrom/greg150mph.wmv
MOD LIST:
Dark Blue 1990 300ZXTT
NEW SET UP
Specialty-Z Built Race Motor
Ross Pitons
Eagle Rods
Crank modified to accept wider rod bearings
Custom wider Clevite 77 Rod bearings
Clevite 77 main bearings
ARP rod bolts
ARP main studs and hardware
1mm over sized valves and custom valve seats
massive ported heads
JWT 500 cams and springs
Jun Adjustable exhaust Cam Gears
lower intake manifold ported and polished
upper intake manifold extrude honed and outside polished
powder coated valve covers,coil brackets,fuel lines,water pipes,ect
Z1 Throttle bodies
Specialty-Z SZ900 Turbos
MSP Manifolds
850cc Injectors
Custom Dual Pops
Specialty-Z custom tune with flip switch
Specialty-Z expansion 5 bolt down pipes
Specialty-Z 3" test pipes
Specialty-Z 3" Cat back
Specialty-Z Built Auto Trans
Precision Industries torque converter W/4500 stall and triple lock up clutch
Specialty-Z heavy duty flex Plate
B&M trans cooler with temp controlled fan
B&M engine oil cooler
Blitz SBC-ID III Boost controller and power meter
Apexi AFC-II
hose techniques hoses
Smith hard Pipes
UR crank Pulley and HI water pump pulley
Direct port N20
N20 bottle heater and blanket
N20 blow down tube
N20 purge kit
10 point roll cage with removable door bars
Window net
5 point harnesses
ES rack Bushings
Powertrix Adj camber arms (Front & Rear)
Powertrix Adj tension rods
Specialty-Z Subframe Spacers
ST sway bars
Specialty-Z Lightweight Battery
Corbeau Seats
Hicas Removed
NA power steering pump & brackets
4.10 Leadergears
Brake Man Brake Kit
MOD LIST:
NEW SET UP
Ross Pitons
Eagle Rods
ARP rod bolts
Z1 Throttle bodies
MSP Manifolds
850cc Injectors
Custom Dual Pops
Apexi AFC-II
Smith hard Pipes
Direct port N20
N20 blow down tube
N20 purge kit
Window net
5 point harnesses
ES rack Bushings
ST sway bars
Corbeau Seats
Hicas Removed
4.10 Leadergears
Brake Man Brake Kit
itslogz
37
Dec 16, 2008 08:12 PM
