Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Old Mar 25, 2015, 09:26 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
2004 accord auto 4 cyclinder drive belt replacement, how to?
Old Jun 15, 2008 | 10:51 AM
lakerschamp2000's Avatar
Default 2004 accord auto 4 cyclinder drive belt replacement, how to?
Hi guys, i need to replace that drive belt but don't know how, can you help or is there an article about this job? thanks
Old Jun 15, 2008 | 05:34 PM
BLKFLSH's Avatar
Default Re: 2004 accord auto 4 cyclinder drive belt replacement, how to? (lakerschamp2000)
[IMG][/IMG]
You can probably use a ratchet, instead of the special tool. It's not easy to do, without help, but it can be done. If you have someone else to hold the tensioner, while you position the belt, it's much easier.
Old Jun 17, 2008 | 06:53 AM
JimBlake's Avatar
I hooked 2 wrenches together, basically makes a wrench with a LONG handle. Turn in the direction of tightening the bolt, that springs the tensioner lever over to slacken the belt. It's really not that difficult. You just have to be careful the wrench doesn't slip off.
Old Jun 9, 2009 | 05:10 AM
Charlie Moua's Avatar
Great info... i need to replace mine also.
Questions:
1)what is the milage service for these OEM belts?
2) is this the right part # 38920-RAA-A01
http://www.hondapartsdeals.com/hpa_p...nGroupID=11722
Old Jun 9, 2009 | 12:09 PM
Two400's Avatar
When is the drive belt supposed to be replaced?
Old Jun 14, 2009 | 06:05 PM
R_ACE1's Avatar
lol, i like how the service manual tells you how to install the drive belt.
It should read:
Removal: losen auto-tensioner and remove belt.
Installation: .........really..........do I really have to tell you how to install it????
Old Jun 15, 2009 | 04:22 PM
KWayRacing's Avatar
We change them at 105k at my dealership just like the timing belt/ plugs.
Old Jun 16, 2009 | 05:31 AM
is this the right part # 38920-RAA-A01 ?
Old Jun 23, 2009 | 08:26 AM
Targa250R's Avatar
be professional
For an '03-07 Accord 4-cylinder, yes. 38920-RAA-A02 and 38920-RAA-A03 are equivalents.
You can also use a Bando or Mitsuboshi 7PK-1781.
As mentioned, the standard service interval is 105,000 miles, however I've seen a number of them start to make noise or squeal long before that, requiring premature replacement.
Old Jun 25, 2009 | 02:15 PM
aznkid4now's Avatar
stupid question but i have to ask. whats a drive belt?is it another term for timing belt? also what is a serpentine belt? and also haha dont these k series only have timing chains?
Old Jun 29, 2009 | 05:59 PM
ehulst's Avatar
It runs the Alternator, A/C, Power Steering and Water Pump....yes the K series motors are timing chain...these belts are easy to replace...little tight, but what isnt on a Accord..
Old Jul 5, 2009 | 01:08 PM
BLKFLSH's Avatar
The drive belt, serpentine belt, accessory belt are all names for the same belt. It's the only belt you can see simply by opening the hood. It's spins on a number of pulleys, and drives the A/C compressor, alternator, power steering pump, and water pump. The Timing belt is a whole different belt, and you can't see it by simply opening the hood. There are covers over it. The drive belt can be changed in 10 minutes (by a professional), but the timing belt will take at least a couple of hours to change. The timing belt is behind the drive belt, so you have to remove the drive belt, and some pulleys and pumps, to get to the timing belt. Of course, if you have a 4 cylinder engine, you have a timing "chain" which should never need changing. I hope I didn't confuse you.
Old Sep 10, 2009 | 12:26 PM
shortlid's Avatar
Icon6 Re: 2004 accord auto 4 cyclinder drive belt replacement, how to?
Going to replace the assc. belt on a '03 LX coupe with auto. I can get the serpintine belt tool from loan -a-tool at Autozone. Roting looks crazy on the diagrams. I have the girl that owns the car that can hold the tensioner compressed. Any other advise on how to ease the replacement.
I am guessing the tensiner is auto adjusting, and I will not have to check tenssion in 10k.
Old Sep 10, 2009 | 12:28 PM
shortlid's Avatar
Looking at the diagram if the tension indicator is pointing to the left it is streched and needs replacment. If to far right it is too tight.
Old Aug 29, 2010 | 02:48 PM
HOW do you MOVE/adjust the tensoner pulley so that it will move enough allow belt slack to slide over all pulley?
Okay i'm doing this right now.
I got the old belt off.
To put on the new belt, I looped it on the right spots on all the pulley and saved the alternator pulley for last.
In order to move the tensioner, I have a large flat pinched in between the tensioner and the PS pulley and am pulling the flat upward/toward the front of the car....
The tensioner moves but just not far enough to slide it over the Alternator pulley.
Tips?
I can see that because i'm using the large flat inbetween the tensoner and PS pulley, the TIP if the FLAT is pushing the belt and therefore taking up some belt space. That's the reason why I can't slide it over the alternator pulley.
Old Aug 29, 2010 | 05:34 PM
shortlid's Avatar
I used the "borrow-a- tool" system at the local Autozone to get a serpentine belt tool. VERY long armed wrench to take the tensioner off the belt all together!
sati1234
Dec 24, 2017 05:07 PM
famfive
Jul 25, 2010 08:29 AM
houzful
May 1, 2008 07:08 PM
Gamefreak0109
Aug 9, 2007 10:13 AM
essenz
Feb 7, 2005 10:22 PM
