rocker arm shaft removal b16
Old Jun 15, 2008 | 10:08 AM
black0hatch's Avatar
Default rocker arm shaft removal b16
i understand how it comes out but how do i get those little oil jet things out? basicly those little things are whats holding the shaft in there right? it looks like there threaded so you can stick a bolt in there and just pull them out? what size bolt is it? then once i get those out thread a bolt into the shaft and pull it out?
Old Jun 15, 2008 | 07:57 PM
itralex's Avatar
Default Re: rocker arm shaft removal b16 (black0hatch)
needle nose pliers work also
Old Jun 15, 2008 | 08:49 PM
rebo0t's Avatar
Default Re: rocker arm shaft removal b16 (itralex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">needle nose pliers work also</TD></TR></TABLE>
x2
or you can find a bolt and thread it in to pull it out. either/or will work
Old Jul 3, 2009 | 12:15 AM
ema's Avatar
ema
New User
Nose pliers will do but I can recall a tool that is specialized in removing rocker shaft. I just can't figure out the name.
Old Jul 3, 2009 | 12:31 AM
Combustion Contraption's Avatar
He's asking about the oil jets, not the shafts themselves. Parts numbers 3 and 4 in this pic.
Yes, they are threaded to screw fasteners in to pull them out, if you dont have the correct sized fasteners handy, you can stick a slim flat head screwdriver in the rocker arm shaft bore and just pry up , they will pop up with very little force.
Raebranch
Jan 5, 2017 09:29 AM
1997 Odyssey LX
Oct 30, 2013 11:17 PM
dleccord
Jan 10, 2010 03:35 PM
GsrTurboCRX88
19
Nov 21, 2006 06:12 PM
hondaZvic
Jun 12, 2004 03:58 PM
