b18c1 into 96-00 civic
Old Jun 14, 2008 | 06:21 PM
acura_b18c1's Avatar
Default b18c1 into 96-00 civic
Hi .. i ve been reading the FAQs section to figure out what is neccesary to install a b18c1 into a 96 civic EK hatch. It said to use a EM1 rear bracket , shift linkage , and mounts. But my question is , if i already have hasport mounts , shift linkage , rear mount bracket , axles , wireharness from a 94-00 integra dc2 .. can i re use all of that ? is there anything else i need on top of that ? .. thanks
Old Jun 14, 2008 | 06:33 PM
elektronsi's Avatar
Default Re: b18c1 into 96-00 civic (acura_b18c1)
you should be good to go
Old Jun 14, 2008 | 08:26 PM
luvmihatch's Avatar
Default Re: b18c1 into 96-00 civic (elektronsi)
yeah u should be able to when i put my ls into my hatch the only thing i had to change was the rear t mount out of the 99-00 si.. as u stated. but axels, shift linkage etc should come with your swap but u can reuse all ur stuff from the dc2.
Old Jun 14, 2008 | 08:28 PM
mnskateboarder's Avatar
you'll need the 99-00 si drivers side bracket/post mount instead of the gsr one and the front tranny bracket as well from a integra or si, and the si T bracket.
Old Jun 14, 2008 | 09:08 PM
EGhatch87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura_b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Hi .. i ve been reading the FAQs section to figure out what is neccesary to install a b18c1 into a 96 civic EK hatch. It said to use a EM1 rear bracket , shift linkage , and mounts. But my question is , if i already have hasport mounts , shift linkage , rear mount bracket , axles , wireharness from a 94-00 integra dc2 .. can i re use all of that ? is there anything else i need on top of that ? .. thanks </TD></TR></TABLE>
youll need EM1 rear T-Bracket, EM1 driver side post bracket..you can use stock 96-00 rubber mounts and tranny bracket..DC axles, linkage will work...DC harness mounts,and brackets wont work
Old Jun 14, 2008 | 09:14 PM
^ you can resue the top tranny bracket, but not the front bracket.
curioso
Nov 12, 2009 08:23 PM
tysonboy
Jul 30, 2009 04:52 PM
Adrian G. Aka JDMonkey
Sep 9, 2007 10:12 AM
sol_1320
Jul 11, 2005 12:29 PM
Se-rv-Tak
Nov 29, 2003 11:59 AM
