Finally cranked my ls/v ::video::
Old Jun 14, 2008 | 04:41 PM
skoodles2k6's Avatar
Default Finally cranked my ls/v ::video::
http://www.youtube.com/watch?v=d9uvLCsOCiM
finally got my ls/vtec cranked
81.5mm b18b block
81.5mm rs machine heat treated pr3 pistons
LS rods
ACL RACE Bearings
OEM GSR oil and water pump
Arp Head studs
Arp Rod Bolts
4-1 header
CTR head
Supertech Valve springs and retainers
CTR throttle body
Blox HSL cams
Golden Eagle adjustable camgears
BLOX cam seal
MSD 6AL
MSD 8.5mm wires
MSD blaster ss coil
the car doesn't want to idle im thinking its the tps sensor i swaped it from another tb cause the plug was broke off and i need to look up the procedure on how to calibrate it. that and we did a compression test 230,230,205,230 but i'm hoping maybe the rings just didnt sit yet cause i havent ran the car but for more than 15 seconds at a time and only cranked it about 3-4 times. i think once we get the idle fixed. just let hte motor break in idling and then take it to the dyno and get it tuned
any one got any ideas on the idling issue lmk im open to option i have all extra vac ports blocked off. fpr set at 45psi. lmk what you guys think. its my first honda build. thats taken me about 2yrs almost.
stratedrm
28
May 21, 2009 07:38 PM
SmoothCTR
21
Sep 29, 2008 08:44 AM
peanuts8888
Oct 12, 2006 06:55 PM
peanuts8888
13
May 16, 2006 01:29 PM
racingant
Feb 2, 2006 04:37 PM
