ef hatch with B16a swap, obd0. Cluster wiring help!!!!
Old Jun 14, 2008 | 03:28 PM
MisterBlaze's Avatar
Default ef hatch with B16a swap, obd0. Cluster wiring help!!!!
Ok, I have a 88 civic hatch with a b16a swap and obd0 ecu. I just got the car and the swap was half way done, i have got it running really well and its almost done. The only issue is that my cluster does not work at all. I have a crx sir wiring harness and the stock ef cluster. Can anyone point me in the right direction or should i just upgrade the cluster. Thanks. MB
Old Jun 14, 2008 | 07:43 PM
flatblackfury91's Avatar
Default Re: ef hatch with B16a swap, obd0. Cluster wiring help!!!! (MisterBlaze)
i done the same swap just used an si harness. you might want to get an sir cluster
Old Jun 14, 2008 | 08:06 PM
yeah thats what i am thinking, does the sir cluster use an electronic speed sensor or can i still use the cable one i am using now. i just want to make sure i order all of the right parts.
Old Jun 15, 2008 | 11:48 AM
Default Re: (MisterBlaze)
i think you can use the cable one.im not for sure. my car was a standard so i swapped the cluster for an si one
ohaileo
Aug 10, 2017 09:51 PM
tast2s
Aug 23, 2012 08:21 PM
ffdrift101
Feb 22, 2012 04:26 AM
njn63
Feb 25, 2003 12:01 PM
