Retainer to guide seal contact while degree'ing
KJ and I were degree'ing the Skunk2 Pro 1 cams on TheRedDragon's motor. Exhaust side was fine. We're running into retainer to valve guide seal contact and can't continue. It's the older Skunk2 retainers. Does anyone know for a fact the newer retainers give you more clearance? Any ideas? Spoke over the phone to TheRedDragon. He is going to give Skunk2 a call on Monday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha »</TD></TR><TR><TD CLASS="quote">KJ and I were degree'ing the Skunk2 Pro 1 cams on TheRedDragon's motor. Exhaust side was fine. We're running into retainer to valve guide seal contact and can't continue. It's the older Skunk2 retainers. Does anyone know for a fact the newer retainers give you more clearance? Any ideas? Spoke over the phone to TheRedDragon. He is going to give Skunk2 a call on Monday</TD></TR></TABLE>
was this at skunk2s recommended degree settings for ZERO, or straight up zero TDC?
also are the ssprings used? if so how long and what brand are they alpha?
i have seen coilbind before on a few different springs with high lift cams due to the inner not collapsing far enough
