Wheel Problem...
Well ive been working on my wrecked coupe n im almost finished with it... But theres a problem i came across it while fixing it.. The Front left wheel is bent pretty bad.. And the lower ball joint is scrapping up against the brake disc.. i have already replaced the lower ball joint with a new one.. im thinking the lower control arm is bent and thats whats causing it to scrape up against the disc.. Any help would be appreciated. Thnx..
This is what the wheel looks like with rim on..
As you can see the lower ball joint is up against brake shield..
heres another angle..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ElGsRcOoP »</TD></TR><TR><TD CLASS="quote">
I can't see anything actually. Pictures aren't working.
hachilovr
Aug 9, 2018 04:07 AM
