Can i swap out TD04 turbo exhaust housing?
Old Jun 14, 2008 | 12:46 AM
turbocivic1984's Avatar
Default Can i swap out TD04 turbo exhaust housing?
I have a wrx TD04 turbo on my setup, My turbo has alot of play. I already have my manifold for that turbo. A buddy is going to be giving me a 1st gen dsm turbo which is also a TD04 in good shape. Can i swap the Wrx exhaust housing onto the 1st gen dsm turbo so that it matching my manifold? Anyone done this? Iv tried looking and thought i would ask honda-tech for some help.. thanks..
Old Jun 14, 2008 | 05:55 AM
TheShodan's Avatar
Moderator
Default Re: Can i swap out TD04 turbo exhaust housing? (turbocivic1984)
typically no. TD04 designates the cartridge and housing set, not the wheel sizes. There are many turbos with the TD04 designation, but doesn't mean that they simply can cross over.
Old Jun 14, 2008 | 05:57 AM
Default Re: Can i swap out TD04 turbo exhaust housing? (TheShodan)
IF its the same size it should work? iv never swapped out exhaust housings before, but my turbo went bad and the wrx flange i put on my manifold when i made it is the 3 bolt one..
Old Jun 14, 2008 | 06:02 AM
TheShodan's Avatar
Moderator
Again, not necessarily. THe only way to be sure is to try it, in your case. I believe that the exhaust wheels are different, so there may be some fitment issues.
Old Jun 14, 2008 | 06:03 AM
where could i find the wheel size for both turbos. 2003 wrx td04 13g wheel size and the 1st gen dsm automatic turbo wheel size?
ok thank you..
Old Jun 14, 2008 | 11:28 AM
TheShodan's Avatar
Moderator
This may be of help:
http://www.stealth316.com/2-3s-compflowmaps.htm
Old Jun 21, 2008 | 10:51 AM
hey i swapped the 1st gen dsm auto turbo into my wrx exhaust housing and it fit great! just thought i would let you know the outcome.. thanks alot .. and give me a few hours to drop the motor in and hook everything up and let you know how it runs its been 5 months since its been down so im getting excited..
Old Jun 22, 2008 | 09:44 PM
TheShodan's Avatar
Moderator
Good.. Thanks for the update.
a1320honda
Oct 29, 2014 10:50 PM
DAteg2
Dec 6, 2011 12:21 PM
teler86
Oct 6, 2006 01:28 PM
self_made
Sep 30, 2002 11:10 AM
