wanker clutch problems...help!!
Old Jul 17, 2002 | 11:27 AM
wall of tvs's Avatar
Default ****** clutch problems...help!!
ok, i've spent a great deal of time searching for the solution to this, but i haven't found anything that really helps me out w/my problem (so don't flame me).
anyways, here's the deal. this problem only occurs after driving my car for a while (i.e. 10-15 minutes). what happens is that i get a loud creaking/groaning noise when i push in the clutch pedal. it is coming from somewhere in the engine bay. also, the pedal feel changes -- it gets harder to push, and is not smooth feeling like when the car is cold.
i've already changed out the slave & master cylinders, but that didn't do sh*t. it seems to me that something is heating something up, causing this annoyance (i must note that this problem started to happen after i took off the upper heatshield of my cat - damn noisy rattle) since it only starts to happen after driving around for a while.
the clutch still engages at the same point, there is no slippage, and it is still easy to move the shifter into every gear. also, there is no grinding.
what the hell is going on?? i've already spent over 300 bucks, and i don't want to drop the tranny, only to have this problem come back again!! any feedback is much appreciated!!
Old Jul 17, 2002 | 11:40 AM
GSRwBOOST's Avatar
Default Re: ****** clutch problems...help!! (wall of tv's)
I have the same problem
creaking and squeeking... clutch pedal noises.... car drives fine..
mine i think is the clutch throwout bearing which stops making as mjuch noise when i push the clutch in...
replacement si coming..
Old Jul 17, 2002 | 01:03 PM
junglistgsr's Avatar
Default Re: ****** clutch problems...help!! (GSRwBOOST)
mine does the same thing, throwout bearing clutch, clutch master cylinder, clutch slave cylinder has all been replaced, it also has been bled....still does that same crap. it drives me infuckingsane.....im going to pull the slave cylinder out tonight and grease it up like mad with some white lithium grease.
Old Jul 17, 2002 | 01:32 PM
GSRrR's Avatar
Default Re: ****** clutch problems...help!! (junglistgsr)
Same thing happens with me. I did have the throwout bearing replaced when I had my clutch put in in feburary. The weird thing is that it goes away sometimes. Also if I do not drive the car the a day or two, the clutch feels smoother but once I drive it, the noise would come back and it would get harder and harder to push in the clutch. If anyone find a solution please let me know. I have tired greasing the "push rod" thingy where the fork is just like another member did on this board but the noise is still there.
Also how do you know if you need to bleed the clutch? What are some symptoms of air in the system? TIA
Old Jul 17, 2002 | 01:33 PM
Default Re: ****** clutch problems...help!! (GSRrR)
i think that if there is air in the system, the pedal actually gets softer to push in. THIS IS DRIVING ME NUTS
EDIT: for those of you w/this problem -- do you still have the heatshields on your cat?? i'm beginning to wonder if this is the solution to our fvcking problems -- since the cat is directly below the firewall. just a thought.
[Modified by wall of tv's, 4:36 PM 7/17/2002]
Old Jul 17, 2002 | 01:36 PM
GSRrR's Avatar
hmmm maybe I have to bleed it. When I frist got my car back after the clutch replacement, it was really easy to puch the clutch pedal in. Thought it was normal because I heard clutchnet's pressure plate is softer than oem.
Old Jul 17, 2002 | 01:43 PM
i am also going to adjust pedal freeplay tonight and grease the clutch master cylinder rod that comes through the firewall with a bit of grease around it....that might cause problems....who knows. It makes me not want to drive my car though...i think heat is a culprit of part of the problems though....
Old Jul 17, 2002 | 01:51 PM
yeah, so my question is this -- do you guys still have the cat heat shields on?? i noticed that this problem started to happen after i took those noisy bitches off...
Old Jul 17, 2002 | 02:03 PM
i do.
Old Jul 17, 2002 | 02:25 PM
GSRrR's Avatar
please let us know if that will find the problem junglistgsr. Well I still have the heat shield on. No cat though. Maybe it's heat from my turbo cause it's right next to the shift fork?
[Modified by GSRrR, 3:26 PM 7/17/2002]
Old Jul 17, 2002 | 02:27 PM
no turbo on my ride....isn't this fun??
my only "engine" mods are I/H/E.....
Old Jul 18, 2002 | 09:37 AM
junglistgsr -- did your lube job work out for you??
Old Jul 18, 2002 | 09:40 AM
didnt get a chance to do it.. will try tonight if i have time
Old Jul 18, 2002 | 06:27 PM
GSRrR's Avatar
cool. please let us know. It's driving me nuts.
Old Jul 22, 2002 | 11:16 AM
well, i took out my slave cylinder, greased the hell out of the ball end, and completly flushed out the old fluid in the system...
...didn't do ****!!! still getting problems after car warms up. looks like i'll have to wait until i change out the clutch to replace everything in there to clear things up
Old Jul 23, 2002 | 12:53 AM
GSRrR's Avatar
Damn it. I do not really want to have to get the clutch taken out again. Please do not tell me that the throw out bearing needs more grease.
sz9182
Aug 2, 2007 11:41 AM
tegasaurus
May 5, 2004 03:56 PM
wall of tvs
Jul 18, 2002 09:50 AM
