Explain advantages of using a gsr block on a b16 head.
Old Jul 17, 2002 | 11:23 AM
drunken jdm monkey's Avatar
Default Explain advantages of using a gsr block on a b16 head.
Herd alot of talk about gsr blocks with b16 heads an since I have a b16 was thinking of doin this.So what are the major advantages of this set up an could a I use an ls crank an ctr crank pulley?
Old Jul 17, 2002 | 11:24 AM
kinesistech's Avatar
Default Re: Explain advantages of using a gsr block on a b16 head. (drunken jdm monkey)
None, unless your turbo and need to lowe compression. Thats all that will happen. Ls crank will conflict with the oil squirters I think. Use which ever pulley you please.
Old Jul 17, 2002 | 11:27 AM
Default Re: Explain advantages of using a gsr block on a b16 head. (kinesistech)
I have herd rumors that this adds alot of torque to the b16 an is somthing you would want to do in an allmotor car.It was either gsr or ITR.
Old Jul 17, 2002 | 12:16 PM
B_CRUZ!'s Avatar
its a good combination if you add B16A pistons in the gs-R block.
Old Jul 17, 2002 | 12:20 PM
Default Re: Explain advantages of using a gsr block on a b16 head. (B_Cruz)
I was planning
jun stage 3
jun cam gears
mild p&p
ctr crank pulley
crower springs an retainers
ctr pistons
gsr or itr short block
Old Jul 17, 2002 | 12:40 PM
B_CRUZ!'s Avatar
then in that case the gs-r block is fine
Old Jul 17, 2002 | 01:12 PM
so back to the orignal ?.What advantages will I have with using a gsr block in this set up.What will I be gaining an what will I be losing.Also what advantage woulld an ITR block have over the gsR
Old Jul 17, 2002 | 02:03 PM
Default Re: Explain advantages of using a gsr block on a b16 head. (ridge racer 2)
ridgeracer your only 1 person to have said somthing negative abou this,want to back your claim up?I was told using an itr block would gain some nice torque.
Old Jul 17, 2002 | 02:09 PM
slooowDX's Avatar
no differences between GSR and Type R blocks (bare blocks) if i were you, just go straight GSR, get all that stuff you posted you wanted to do to the GSR, but install P30 B16A pistons instead of the CTR's, little more on the safe side compression wise, then add a Skunk 2 intake mani. i've seen GSR ported heads flow better than GSR ported heads, i think the GSR head has a taller intake port, supposed to be better, well HTH
Old Jul 17, 2002 | 06:21 PM
deez92's Avatar
more torque
Old Jul 17, 2002 | 07:51 PM
Default Re: Explain advantages of using a gsr block on a b16 head. (deez92)
ok.so sloowdx when you refer to the p30a b16 pistons are you referring to using my stock pistons?Also I dotn need a skunk 2 manifold I already got an ITR.My car currently runs 13.4 at carlsbad an I want to do an all motor set up to get into the 11's dailydriven.
Old Jul 17, 2002 | 08:23 PM
fowler!'s Avatar
This is what I'd do if I were you.
Seeing as you're ripping apart the motor and adding all the stuff you say you are, I'd recommend JDM ITR pistons (USDM P30/PR3 are basically the same thing, so you could use those if you are on a budget) and a 2 layer head gasket. That should put your compression somewhere around 11.2~4:1, which would be a good thing if you are going all motor.
You don't need a Skunk2 manifold, you can get one, but it would be the same thing as an ITR IM, but more expensive.
At the end, if you p&p and add some cams, it's basically going to be the same thing as an ITR motor.
Switching to a GSR block would be a good idea imo, torque is always a good thing when it comes to Honda motors
Old Jul 17, 2002 | 08:36 PM
Default Re: Explain advantages of using a gsr block on a b16 head. (fowler!)
ok so since ITR pistons came up,whats the diffrence between using these an CTR ones.Right now I can get CTR slugs for 225$ so thats why I was planning on usin them.
Old Jul 17, 2002 | 08:52 PM
fowler!'s Avatar
If you use CTR pistons in a GSR w/ B16 head, you're looking at a CR of 12.1~2:1.
That's a little too rich for my blood.
For a street car, I really wouldn't go above 11.5:1
Old Jul 17, 2002 | 08:54 PM
oh ok I see how this makes sense now.Good lookin out on this one.Now what if I did break the rules an did use the ctr pistons,what advantages an disadavantages would I have.
Old Jul 17, 2002 | 08:56 PM
fowler!'s Avatar
It would be a quick motor no doubt. Especially with those cams, it's kick ***.
With proper tuning and enough fuel, it's be a very fun motor.
You just have to be really really careful.
Old Jul 17, 2002 | 08:57 PM
Ok so I can use ctr pistons,thats cool.In whats ways would I have to be careful?
Old Jul 17, 2002 | 08:58 PM
Damon B.'s Avatar
motor mounts are the same between the b16 and b18c, correct? Oh, fowler, why would you have to be careful with this combination motor? Or is it just his higher compression set-up that you say he needs to be careful with?
Old Jul 17, 2002 | 09:00 PM
Default Re: Explain advantages of using a gsr block on a b16 head. (CleanSi)
Ya I am curious to what precautions I would have to watch out for?over revving? using the wrong gas,any more?
Old Jul 17, 2002 | 09:03 PM
fowler!'s Avatar
The mounts are different between the B18C and the B16..but that's only because the motors come in different cars. The mounts are interchangable, so, you can put a B18C into a B16 equipped car with no sweat, make sense?
Yeah, the only reason you'd have to be careful is because of the compression. It's pretty high, so detonation is possible without correct tuning.
I've heard that you can run them with no problem, but...I'd be careful, like I said.
Old Jul 17, 2002 | 09:04 PM
fowler!'s Avatar
If you had access to higher octane gas, you'd be cool, but with what most people have, 91, seems like it'd be a little low.
Old Jul 17, 2002 | 09:05 PM
so what would be some precautions to prevent detonation with this set-up?My goal is an 11sec daily driver.
Old Jul 17, 2002 | 09:08 PM
fowler!'s Avatar
high octane gas, retard your ignition
Old Jul 17, 2002 | 09:10 PM
seeing as I have acess to some 101 octane locally but not when I am away from the area of this gas station would using 91 somtimes be ok?THANKS A MILLION MAN.
Old Jul 17, 2002 | 09:12 PM
fowler!'s Avatar
Like I said, be careful, with compression like that I wouldn't be pounding on the motor.
101 should work nice
