replace driver's side headlight bulb - 2002 accord
Old Jun 13, 2008 | 05:08 PM
2002accordtx's Avatar
Default replace driver's side headlight bulb - 2002 accord
The driver's side lowbeam on my 2002 accord burned out and I need to replace it.
There's a plastic cover of them that is connected to the frame with plastic push pin looking pins that don't come out unless you can pinch the back of them (which I can't).
The only other things looks like to remove the air filter assembly.
Am I missing something? Is there an easy solution to getting access to and then replacing this bulb?
Thanks in advance.
Old Mar 21, 2011 | 01:50 PM
bigwebb83's Avatar
Default Re: replace driver's side headlight bulb - 2002 accord
bump. I also need the answer to this. Why in the hell would they make it so difficult to access a bulb?
Stevo F
Mar 27, 2014 04:49 AM
blackv6
Apr 30, 2006 08:19 PM
sdsviet
Aug 15, 2004 01:54 PM
mechanicallyinept
Jan 1, 2004 02:35 PM
beantowncoupe
Apr 24, 2003 11:50 AM
