vafc wiring
Old Jun 13, 2008 | 11:32 AM
(760)doogie's Avatar
Default vafc wiring
hey so im trying to hook up my vafc ii but i cant find what color is for what because it doesn't say it on the website.
Old Jun 13, 2008 | 11:50 AM
89hatcher's Avatar
its in the FAQ up top.
but here you go
V-AFC VTEC controller -------> ECU PIN location
Red & Orange wire splice/connect to A15 (yellow/black)
Green wire RPM signal splice/connect to B15 (white1)
Pink wire VTEC signal output to VTEC solenoid (green/yellow)
Purple wire VTEC signal input not used on PM6 ecu
Blue wire VTM signal not used on PM6 ecu
Gray wire Throttle signal splice/connect to C7 (red/blue wire)
Yellow wire Pressure signal output cut/connect to C11 ECU side harness
Si/Hf = white1 , DX = orange
White wire Pressure signal input cut/connect to C11 ENGINE side harness
Black wire Ground splice/connect to A16 (brown/black wire)Engine side harness
Brown wire Ground splice/connect to A16 (brown/black wire)has to be connected closer to the ECU
Old Jun 13, 2008 | 11:56 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (89hatcher)
better yet, don't even bother with a vafsuck
Old Jun 13, 2008 | 01:33 PM
Default Re: (***$nyper)
just finished up the wiring thanks, im gunna go crome once my project hatchey is running, im just hooking up the vafc ii if i need to go wide open throttle, becuz im just gunna baby it until i break in the motor so itll just be running off the o2 sensor that i just convert to 4 wire
Old Jun 22, 2008 | 08:29 PM
eF9dc5Dan's Avatar
would the vafc ii diag. u posted wrk for a vafc1 da old version ..obd0 ef9 w/t b16a
MotoCARR
11
Dec 21, 2006 01:03 PM
Suck my DX
May 14, 2006 04:57 PM
AZTEKEF9
May 27, 2005 06:05 PM
aces1980
Aug 1, 2004 10:05 AM
