4 cel code, cranshaft sensor...help????
Old Jun 13, 2008 | 11:06 AM
vtec213's Avatar
Default 4 cel code, cranshaft sensor...help????
I did a search and couldn't find much on this topic....
Ok so i have a 93 honda accord ex with 160K miles but with a rebuild engine only a year ago. Anyways recently the car takes a while to turn on and when it does the engine sounds rough. I checked the Cel Code and it gave me a 4: crankshaft position sensor. Now, i have no idea what that is. I am pretty sure my car has a vacuum leak as you could hear air slipping out of the engine but that was before the cel gave me this code. As I said earlier now my car has trouble starting and it and the engine has lost a lot of power when im driving.
Any ideas? could my timing be off? or is it just the sensor? and if so, how would i go about fixing this problem.
Any help would be appreciated...thanks
Old Jun 13, 2008 | 11:18 AM
Mr Yamada's Avatar
Default Re: 4 cel code, cranshaft sensor...help???? (vtec213)
For your year of Accord the Crank Position Sensor is a pulse counter located in the distributor housing.
Old Jun 13, 2008 | 11:23 AM
vtec213's Avatar
Default Re: 4 cel code, cranshaft sensor...help???? (Mr Yamada)
how could i get to it to check it? or replace it? sorry this is the first time i have come across this problem.
Old Jun 14, 2008 | 07:03 AM
Mr Yamada's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec213 &raquo;</TD></TR><TR><TD CLASS="quote">how could i get to it to check it? or replace it? sorry this is the first time i have come across this problem.</TD></TR></TABLE>
I will email to Mr Hondadude for the technical testing of that component, I do not have access to that type of information.
Old Jun 14, 2008 | 11:01 AM
Mr Yamada's Avatar
dustin3
Mar 25, 2012 11:17 AM
XmkncX
Nov 12, 2011 12:21 PM
lunarone
Oct 1, 2009 01:27 PM
infam0us3o5
Jun 12, 2007 04:49 AM
