starting troubles
as the title says, starting troubles. it has never happened to me before but in the last couple of weeks it has happened maybe 2 or 3 times. when i go to start the car it will turn over and keep turning over. the way i can get it started is by flooring the gas pedal and it will slowly start and then it will run how it should. im really kind of confused. im pretty sure the fuel pump is working because it will run after it starts with no problems at all. could it be the main relay? maybe the ignitor? help is appreciated. thanks
LilMissCrystal81
Nov 19, 2004 11:26 AM
