EK throttle cable bracket / direction
Old Jun 13, 2008 | 06:58 AM
stevew84's Avatar
Banned
Default EK throttle cable bracket / direction
ok i have a b18c1 in my 97 ek and about to install the throttle cable bracket and also the correct cable....(gsr)
couple questions.
-which direction does the cable run (up from pedal connect to TB from timing belt side or loop around valve cover and connect to TB from dizzy side)
-since i do not have the stock TB will the stock teg gsr throttle cable bracket match up? its a thin piece of metal if i need to drill out a hole or two thats fine just curious.
thanks
Old Jun 13, 2008 | 07:23 AM
4doorek96's Avatar
Default Re: EK throttle cable bracket / direction (stevew84)
comes up from the timing belt side on mine good luck
correction im a dumba$$ and didnt read the whole post i didnt see gsr, very sorry
Modified by 4doorek96 at 11:34 AM 6/13/2008
Old Jun 13, 2008 | 07:28 AM
stevew84's Avatar
Banned
correct me if im wrong but the throttle cable bracket goes on the TB which is on the dizzy side...how does the cable meet with the bracket if it comes up from the timing belt side?
pics?
Old Jun 13, 2008 | 08:58 AM
j_scobar's Avatar
Default Re: (stevew84)
I recently dropped a JDM B18C in my 96 and what I did was removed the GSR bracket (which was pointing the wrong direction for my set up) and used the one from my original motor, I may have even turned it around 180 deg. I can't really remember off the top of my head but I haven't had any problems. I did have to open the grove itself on the throttle body a little to accomidate for the slightly off centered line up but it worked fine I can take a pic of it later if you still need it. My whip's sitting in the garage today, it was suppose to rain so I brought the truk wrk .
Old Jun 13, 2008 | 09:14 AM
stevew84's Avatar
Banned
ok what is your "set up" and basically your saying it doesnt matter if it comes from either direction...i know type r's pull from the opposite directions as other integras so that means they have a short cable.....the GSR cable is longer compared to b16s.
yes i still would like to see a pic
Old Jun 13, 2008 | 09:22 AM
stevew84's Avatar
Banned
the reason why im doing all of this in the first place is...
a. the guy i bought it from has an LS cable attached..too long.
b. no bracket whatsoever so when i hit the slightest bump while accelerating, the cable wiggles and make the engine rev high then normal, high then normal. gotta put in the clutch to correct problem.
Old Jun 13, 2008 | 09:35 AM
j_scobar's Avatar
Yeah I getcha, that's no way to drive, I'll get you a pic when I get to the house later today.
element1791
Dec 23, 2014 05:35 PM
TypeRfit
Feb 26, 2012 06:54 PM
Crank
Nov 7, 2008 02:30 PM
boostingisfun
Aug 27, 2007 04:54 PM
jdm_vtec
Aug 7, 2007 04:25 PM
