Factory Sunroof install question
Old Jun 13, 2008 | 05:52 AM
Fullthrottle297's Avatar
Default Factory Sunroof install question
Anyone every install a factory sunroof in an EK hatch
just looking for any info or advice on how to do this with as little headache as possible
i have the sunroof with wiring and switch plugged it into the fuse box under the dash and it functions correctly i know i will need a new headliner or just cut the old one but as for the installation and cutting the roof
i havent taken my headliner off yet will the sunroof bolt right in
Old Jun 13, 2008 | 07:27 AM
4doorek96's Avatar
Default Re: Factory Sunroof install question (Fullthrottle297)
it should but right in but a headache is going to come with it and be sure to seal it the right way the first time so your not taking a showing the next time it rains good luck
Old Jun 13, 2008 | 08:46 AM
Default Re: Factory Sunroof install question (4doorek96)
its not a universal sunroof its the factory slider theres real sealing it has a rubber strip that meets part of the roof that is bent down and if it does leak the sunroof frame catches it and it drains out of the four corners so really the only sealing would be the rubber seal around the glass to the roof if thats all i have to do
any one ever try or accomplish this ?
Old Jun 13, 2008 | 08:48 AM
maxaldinger's Avatar
My friend put a sunroof into his EK, it wasnt the OEM one though.
Old Jun 13, 2008 | 08:58 AM
instructor74's Avatar
I think your in for a rude awakening when you try and do this if I am not mistaken it will be more then just cutting a hole in the roof of your car. the factory sunroof mounts to channels that are a part of the roof sheetmetal, non sunroof cars do not have them. The way I have heard of most people doing it is to cut out the roof and install the roof sheet metal from a sunroof car
Kid1320
65
Apr 23, 2008 05:12 PM
cbmprelude
Jul 17, 2006 08:01 PM
sd.coupe
Oct 4, 2005 08:59 AM
99hatch
Jan 17, 2005 12:36 PM
2000CX
Jan 14, 2003 06:04 PM
