Best .bin dump for Honda's? I need a couple different ones.
Old Jun 13, 2008 | 12:02 AM
TwoKSiR's Avatar
Default Best .bin dump for Honda's? I need a couple different ones.
I need Hondata and Crome.
First: S200 or Crome (I will run either for now but would prefer S200)
ITR
11.4:1
Sk2 Stage3 cams or BLow HSL cams
Second: S300
Stock GSR
Ramhorn turbo kit
anywhere from 3-10psi
t3/t04e or close to it turbo
Old Jun 13, 2008 | 12:47 PM
zccr-xsi's Avatar
i can make u a base but ill need to know more then that?list your entire set-up.
Old Jun 13, 2008 | 07:53 PM
TwoKSiR's Avatar
Default Re: Best .bin dump for Honda's? I need a couple different ones. (TwoKSiR)
GSR block 81.5mm 11.4:1
RS Machine pistons (cast pistons)
stock rods
block gaurd
ARP rod bolts and head stids
ITR head
Blox HSL cams
stock ports and runners
ITR intake mani
B16 TB
Port FLow duals and retainers
Omni power USA flat faced valves
Cometic head gasket
AEM ITR cold air
JG Edelbrock header 4-2-1
itr cat
apexi n1 cat back exhaust
obd1 p28
anything else? Thank you sooo much.
Old Jun 14, 2008 | 06:24 AM
zccr-xsi's Avatar
PMED!
Old Jun 14, 2008 | 05:39 PM
norconex's Avatar
Default Re: (zccr-xsi)
http://www.xenocron.com/bins
MurdersV8s
15
Feb 12, 2008 04:04 PM
Eklsv-t
10
Feb 6, 2008 07:51 PM
RACING INTEGRATION
10
Dec 10, 2007 12:56 AM
jaydmcrx
Jan 17, 2005 11:31 AM
rodimus
Dec 27, 2004 02:36 PM
