When replacing your oil pan gasket Do you guys use silicon
Old Jun 12, 2008 | 06:39 PM
averyvm's Avatar
Default When replacing your oil pan gasket Do you guys use silicon
Hey i just replaced my gasket. for the third time allow me to explain
1. The first time I was putting the motor together and I used a new felprow gasket and no silicon (it leaked)
2. Because of money issues I figured that I was gonna drop the oil pan and put some silicon(RTV Ultra Black) with the old gasket
3. Next I got some advance auto parts store credit and bought a new felpro gaske and put that on with some silicon and now I thinks thats leaking.
Anyways I was just wondering what you guys do.
Old Jun 12, 2008 | 06:42 PM
Dasfinc's Avatar
Default Re: When replacing your oil pan gasket Do you guys use silicon (averyvm)
Do you torque it in the right order and with a torque wrench?
If you torque them in the wrong order, or tighten them randomly with a 'cork' gasket, it will leak nearly 100% of the time.
With a Rubber gasket, you have SOME le-way, but regardless, I am willing to bet you aren't using a torque wrench or torquing them in sequence.
*edit*
I now see you are boosted, do you have a decent crank-case breather setup? IIRC you need to modify that so you aren't boosting your oil pan
Old Jun 12, 2008 | 06:44 PM
northkai3's Avatar
Default Re: When replacing your oil pan gasket Do you guys use silicon (Dasfinc)
buy a honda gasket and some honda bond or ultra flange2 in the squirt bottle, u only put the gasket sealer on the ends. ur other option is to go to honda have them do it and if it leaks you have a 12 month, 12k mile warranty on parts and labor
Old Jun 12, 2008 | 06:47 PM
psychotic7's Avatar
Hondabond and the Toyota sealant is the stuff everybody uses...far superior than the cheap Autozone crap....only thing is, it's like 20 bucks a tube
george34
Nov 9, 2016 09:44 PM
hYbRid_Eg6
Feb 12, 2012 06:14 PM
TurboEM1
Aug 28, 2007 06:18 AM
firewalkerr
Feb 13, 2006 05:56 AM
keebler65
Oct 4, 2002 08:40 AM
