door hinges noises
Old Jun 12, 2008 | 12:16 PM
SamC's Avatar
Default door hinges noises
The door makes a noise when I open and close it. What do I use for lubcation? W40? or grease?
Old Jun 12, 2008 | 02:50 PM
Mr Yamada's Avatar
Default Re: door hinges noises (SamC)
WD-40 will evaporate rather quickly, and grease will not penetrate as well as needed.
However there are spray can type greases that come out as a watery consistency, to help penetrate small areas then the grease gels to maintain lubrication.
That type of spray grease would do well on door hinges.
Old Jun 12, 2008 | 05:53 PM
hondamark35's Avatar
yeah, i've heard it called 'Viscotine' but like Mr Yamada said starts thin, gets thick. WD-40 is a good temp fix. it'll stop any noise but you'll have to re-apply on a regular basis.
i've tried dry graphite lube, when it works it works well.. but it's hit or miss.
JimmyM86
Honda Civic (2001 - 2005)
Dec 28, 2007 11:31 AM
D16Z6racing
Jun 5, 2007 05:32 PM
bonnyman
Jan 25, 2007 10:13 PM
Eggman
21
Oct 15, 2004 12:20 PM
