Removing ctr headlight clear lense???????please help
Old Jun 12, 2008 | 11:31 AM
2mansi's Avatar
Default Removing ctr headlight clear lense???????please help
ok guys well it seems that i got screwed again but thats too long of a story to get into. The CTR headlights that i got came with a cracked lense and it looks like im stuck with them. What im wanting to do is remove the lense from my ctr headlights and replace it with a lense i got from a mint 00 si headlight that i have laying around. I saw a write-up a couple of months where someone did this exact same thing i am wanting to do but can not seem to find the thread. I have also heard that the best way of removing them is to pre-heat your oven at 300 degrees and when it is ready stick the headlight in there for about 5 min and glue sealing the headlight should melt making it easy to remove the lense.
I guess my question is can someone please help me explaining step by step on how to do this or give me some link to a previous write-up. Also what is the best thing to use to re-seal the headlight once the new lense is in place. Thanks in advance guys.....
Old Jun 12, 2008 | 02:04 PM
actek23's Avatar
Default Re: Removing ctr headlight clear lense???????please help (2mansi)
https://honda-tech.com/zerothread?id=282131&page=1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
- remove bumper
- remove headlights
- remove lights/rubber from unit
- 8 minutes at 200 degrees on tray
- Start prying open with screwdriver....may have to put back in oven for 2 minutes
- tape off turnsignal area
- prime
- paint a few coats (i used charcoal metallic paint)
- let dry
- assemble housing, put back in oven for 8 minutes at 200 degrees
- push back together tightly when hot
- apply silicon to unit for extra water protection
-put back on car.. (duh)</TD></TR></TABLE>
http://digmyhonda.com/h/story....Guide
Start by removing the light bulb from the housing.
- Preheat the oven to 325 deg.
- When the oven is ready, place the headlight housing onto a baking sheet and put it in the oven for appx. 2 min (you may need to repeat this step until the silicon is plyable enough to work with)
- Remove the housing from the oven (with the pan it's on)
- Place the housing on the counter or whatever surface you choose (we used a towel) and put the baking sheet in another spot as you will be using it again
- Use the blunt side of the knife to pry the outer plastic piece away from the housing. You will need to use the heat gun/blowdryer at this point to help you get it apart. Also, be aware of the little clips and be sure to unclip them without breaking or melting them</TD></TR></TABLE>
Modified by actek23 at 3:09 PM 6/12/2008
Iloveyourhonda92
Apr 6, 2010 04:57 PM
2mansi
Lighting
Jun 11, 2008 02:45 PM
2mansi
Jan 24, 2008 08:00 AM
mildly.interesting
Jan 24, 2003 06:50 PM
