eg build
Old Jun 12, 2008 | 10:06 AM
shadowconspiracy's Avatar
Default eg build
i have a 95 hatch i put a obd 0 b16 in it and the old lsd cable trasmission. the spider gear shot out the diff, so now im useing a 99-00 si trans i have axels for a integra with a hydro tans i have a half shaft a hydro trans also the prblem i ran in to is the bell housing bolts for the rear trans bracket will not fit, they just slide right in, did honda increase the bolt size there fo strnthg, i kno that the cable trans are prone to cracking im stuck on theis swap and i need help, on the axel sitution can i order seals for a teg, and will that work
gsr_b20b
Sep 4, 2012 05:04 PM
dustinbs144
Jun 23, 2010 10:36 PM
scspeed
Transmission & Drivetrain
Mar 8, 2009 06:55 PM
