need advice on passing smog
Old Jun 12, 2008 | 12:24 AM
jdmsir96's Avatar
Default need advice on passing smog
i need advice on what would help me pass the smog at the ref... thanx
Old Jun 12, 2008 | 01:39 AM
lv6l's Avatar
Give us a reason why you might thing or what is going against you to make you think you might fail smog and we will try to help you.
Old Jun 13, 2008 | 09:00 PM
jdmsir96's Avatar
Default Re: (lv6l)
well this is the list of what i have..... and if im missing anything to buy like for example new sparkplugs let me know thanx//...
98 cat good condition not broken....
oil change------
new sparkplugs====
new wires ^/////
stock intake new filter-----
stock exhaust and im gonna seafoam the motor like a week b4 i go to the ref..
so wha do u guys think
Old Jun 13, 2008 | 09:08 PM
lilo_goki's Avatar
still no clue dude, what year is ur car, and what year is your motor, what ecu are you running, do u have everything hook up right, etc.
Old Jun 14, 2008 | 03:32 PM
wordsofvenom's Avatar
if you have to do all that work and still worry about not passing, then you should save your money and time and spend 150-250 for a special smog.
Old Jun 15, 2008 | 10:48 AM
lv6l's Avatar
it doesn't require new components to pass smog. as long as you have the oem ones. if everything is to original spec to how it left the factory then you should pass with flying colors. only thing that might hold you back is your o2 sensor. but thats about it.
cvc1393
13
Jul 19, 2009 12:54 PM
PePpeRedDc5
May 4, 2005 08:01 PM
B00ST2nR
May 20, 2002 12:26 PM
