Wheel Hub Removal/Brake Splash Guard replacement
Old Jun 11, 2008 | 05:26 PM
JerryMann's Avatar
Default Wheel Hub Removal/Brake Splash Guard replacement
Hi Everyone,
My first post here... This all started because the splash guard for the front left brakes rusted off. I am trying to replace it. The 3 screws that held the old one on are rusted and I cannot get a screwdriver on them anyway because they are behind the hub. I cannot find any way to remove them without removing the hub. So I removed the axle nut, after much effort, and am now trying to remove the hub. All I can figure from reading posts online is that I need to press it off. Seems some people are recommending totally removing the whole unit from the car, and then (I guess) using a press. I was considering using a gear puller, but the last I read was that it won't work because the bearings are what I am pressing loose, and the gear puller won't handle it. I cannot believe that I need to remove/replace the wheel bearings to replace this splash pan. Can anyone confirm the correct procedure? I guess I could go buy a Haynes manual, or go to the library, but maybe this post will do someone else good as well.
I am ready to do anything but remove the hub. Maybe grind flat the sides of the screw heads and heat them and wish them loose with a vise grip.
Any suggestions would be appreciated...
Jerry
Old Jun 14, 2008 | 08:17 AM
JerryMann's Avatar
Default Re: Wheel Hub Removal/Brake Splash Guard replacement (JerryMann)
Well, I guess I didn't really need any help...
I went out and squirted PB Blaster on the screws, heated them with the torch/tapped them with wrench for two cycles, then a strong clamp with the vise grips... wiggle wiggle, came loose, unscrewed with fingers.
unbelievable what penetrating oil and heat can do. So I finished the job after dinner instead of before.
Jm
oh, yeah, PS: The new part is a full circle of metal, not the crescent shape of the rusted one that fell off. Yes, the hole is smaller than the wheel hub. Yes, I used tin snips to cut it and slip it around the hub. Yes, everything is just fine now.
Olaisen
Suspension & Brakes
Sep 3, 2010 07:20 PM
Mr.Speed
Jun 15, 2010 03:37 PM
stevescivic
Honda Civic (2001 - 2005)
Apr 21, 2007 10:54 PM
SHystrdyGSRtdy
Aug 14, 2005 01:39 PM
apexii
Jun 6, 2002 07:56 AM
