1992 cx main ecu/dash harness questions
Well i started my new build so i pulled my motor and re did the engine harness while it was out as well as cleaned up and tucked the engine bay. I want this set up to be right and nothing short cutted so i would like to fix my ecu harness as well. I will try to post a pic of it, near the ecu plugs it is just a mess. I would like to rewire the whole thing but do not know where to begin. any ideas or input on how to remove the harness and rewire it would be much appreciated
removing the main harness is a bigger job than you think. i just did it in a cx...you have to remove the entire harness from the horn behind the front bumper, through th firewall, behind the blower motor and all the way to the interior fuse box.
