anyone running MTL?
Old Jun 11, 2008 | 11:03 AM
BiG Chris's Avatar
Default anyone running MTL?
Anyone here running Redline MTL in thier trans? How does it feel vs. 10w30
Im running a J1 short gear trans
Modified by BiG Chris at 12:09 PM 6/11/2008
Old Jun 11, 2008 | 11:27 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: anyone running MTL? (BiG Chris)
not a fan, I run GM snycromesh in mine, it's just a better fuild imo.
Never been a fan of redline's stuff honestly or RP for that matter.
Old Jun 11, 2008 | 11:33 AM
Hovey's Avatar
Default Re: anyone running MTL? (***$nyper)
i also run gm snycromesh in mine. helps that i work at GM. i switched to it about a year ago. i have a couple friends that run RP and havent had issues. to each is there own really.
Old Jun 11, 2008 | 04:29 PM
GroundZer0 336's Avatar
i only run honda in mine, but my friend had put synchromesh in his and was horrible, then he put a heavy weight syntetic oil....i would stick to honda mtf.
Old Jun 11, 2008 | 07:10 PM
gator88's Avatar
Default Re: (GroundZer0 336)
I ran it and it was pretty good. I run redline in everything, race motors and also just the stock crx, motor and tranny. When i went to a knew clutch in my dirtbike, I couldnt use synthetic oil any more so I used some leftover REDLINE Superlight Gear Oil in the car trans and it feels better than the MTL. In all honesty though, I am going to try some Syncromesh and see if i can "bandaid" by 2nd gear slight grind at high rpm. MTL, and superlight both improved it from regular 10w-30, but i would like to see if anythign does any better. One thing I found with both REDLINE products, is that downshifts feel a lot smoother. I used to not be able to get into first if until about 12-15mph, now between 20-25 it clicks right in.
Old Jun 11, 2008 | 09:46 PM
BiG Chris's Avatar
Ok i think im gonna give it a try and see how it feels
Old Jun 16, 2008 | 03:41 PM
BiG Chris's Avatar
Ok so after just over 900 miles the tranny feels good a little smoother than the 10w30 ive had in there. Im going to keep using it and maybe when it comes time to change it again ill try the gm syncromesh
speedworks
Jul 12, 2017 04:24 AM
brotu123
19
Oct 16, 2010 07:55 AM
mrsideways
19
Mar 25, 2007 10:13 AM
Matty.
Honda Motorcycles
24
Jul 29, 2005 07:15 PM
siisgood00
13
Sep 18, 2001 04:30 PM
