A-Spec Suspension Camber issues?
Old Jun 11, 2008 | 10:15 AM
preludedriva's Avatar
Default A-Spec Suspension Camber issues?
i was looking around at curryacuraparts.com
noticed that the Aspec suspension said it came with everytihng needed to changeover
it didnt list exactly what it came with
will this affect camber? will i ahve to get after market camber kit or will the change not effect it or will the susp kit come with it?
Old Jun 11, 2008 | 12:51 PM
Todd00's Avatar
I said I don't want a title!
Default Re: A-Spec Suspension Camber issues? (preludedriva)
The car will be able to be aligned to factory specs after the A-spec suspension install.
Nothing else needed.
Old Jun 11, 2008 | 03:52 PM
Default Re: A-Spec Suspension Camber issues? (Todd00)
so all i gotta do is take my car in for an alignment after i swap over?
Old Jun 11, 2008 | 05:27 PM
SkankyEJ7's Avatar
Indeed.
Old Jun 20, 2008 | 02:11 PM
dan12288's Avatar
Default Re: A-Spec Suspension Camber issues? (SkankyEJ7)
no alignment will be necessary.
Old Jun 20, 2008 | 03:17 PM
b18LS's Avatar
Default Re: A-Spec Suspension Camber issues? (dan12288)
Not sure about that last one. With the new suspensions, any time you dissconnect the suspension, specifically the front, you should get it aligned. It wasnt so with the older honda suspension unless you lowered it.
Old Jun 21, 2008 | 09:47 AM
Todd00's Avatar
Default Re: A-Spec Suspension Camber issues? (b18LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18LS &raquo;</TD></TR><TR><TD CLASS="quote">Not sure about that last one. With the new suspensions, any time you dissconnect the suspension, specifically the front, you should get it aligned. It wasnt so with the older honda suspension unless you lowered it.</TD></TR></TABLE>
I agree, but the way Honda engineered the A-Spec suspension is that if you are running OEM suspension and the car is in good alignment, the A-Spec will go right on and usually not be too far out.
They still recommend to get the alignment checked after install, however.
Old Jun 21, 2008 | 01:19 PM
b18LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
They still recommend to get the alignment checked after install, however.</TD></TR></TABLE>
Old Jun 23, 2008 | 08:19 AM
dan12288's Avatar
you really dont need it if your coming from stock... trust i have been riding my car for a year and a half after install and had no issues whats so ever... but i guess if you really want to spend the money to get an alignment, just do it.
Old Jun 23, 2008 | 11:00 PM
thetunersource's Avatar
get it aligned, its not worth it not to do it
Charliegrs
Oct 14, 2006 05:12 AM
p1driftfiend
Aug 12, 2004 06:41 AM
R_Machine
Sep 23, 2003 12:27 PM
Group 03
Feb 20, 2003 07:48 AM
