Brake Lamp Issue
I realized my brake lamp wasn't going on (thats an ez ticket to get when a cop is behind you). So i figured the bulb was bad and it wasnt, the filament was still good. Even though I replaced it with a new 7740 bulb it still did not turn on when the brake pedal is applied. I don't know if the wire is bad or if its a fuse, the trunk light still works and it runs through the same set of wires.
Any ideas on what it could be?
i just posted this, https://honda-tech.com/zerothread/2320459
pull your stoplight switch from behind the brake pedal and use an ohm metter to test continuity, should have continuity between diagonal pins 2 on 2 off and reverse when the switch is thrown, if you dont then you either need to take it a part and clean it or buy a new one for 40 bucks
civicflow
Oct 17, 2007 03:54 PM
