95 gsr
Old Jun 11, 2008 | 09:27 AM
ryintegra32's Avatar
Default 95 gsr
i have a 95 gsr i changed the intake manifold and now the car is revin out at 7200 rpms. it also isnt hitting any vtec. then other times it will run like a gsr and go up to 8200 rpms but only hits vtec till 6500 rpms. any ideas???? ive rewired the vtec ive taken the seloniod off and cleaned it still hasnt made a difference.
Old Jun 11, 2008 | 09:29 AM
St. Jimmy's Avatar
* B A N N E D *
Default Re: 95 gsr (ryintegra32)
What kind of intake manifold did you put on?
How did you rewire vtec?
Do you know the difference between your secondary runners opening and vtec?
Are you still running the stock ecu? any CEL's?
Old Jun 11, 2008 | 09:34 AM
Default Re: 95 gsr (St. Jimmy)
i put on a skunk 2 intake manifold on it. well its a gsr swap it was a ls 2 start out with so i ran all the wires in2 the ecu with the clips. its still a stock p72 ecu
FASTESTCB7inQNZ
Mar 10, 2010 02:32 PM
dannyboys95c
Mar 2, 2009 04:53 PM
ryintegra32
May 28, 2008 04:03 PM
NA JDM GSR
Mar 27, 2006 06:11 PM
GSR -97
Nov 23, 2001 09:01 PM
