crx wire harness help?
Old Jun 11, 2008 | 07:35 AM
ADD_FUEL's Avatar
Default crx wire harness help?
hello,
i have a 90 crx si with a b16 in it with everything original which means its still obd0. now the wiring harness is in pretty bad shape, i was just gonna buy a obd0 to obd1 jumper harness, dizzy, and a tuned p28 but i really dont want to keep the original harness do to that it is in pretty bad shape. is there a obd1 harness that i can just slap on there and without having to cut anything or do any modafications? or is there anyone on here that had the same issue? and if so what did u do to resolve this problem?
sorry i'm a noob when it comes to wiring
Old Jun 11, 2008 | 07:50 AM
punkdown's Avatar
Default Re: crx wire harness help? (ADD_FUEL)
eh... if you want to replace the harness with one from a different car you're going to have to modify it, there is no getting around that. I'm guessing you don't have much electrical experience so your best bet is to get one from another 90 si that is in good shape and just add the wires you need to that one. For my swap I ended up using the harness from the donor car since my stock one was hosed but it was a pain in the *** tracing everything out to meet up with the cabin harness. I really don't recomend that unless you know what you're doing.
You could try to find someone in your area that knows what they are doing and pay them to do the work..
Old Jun 11, 2008 | 10:30 AM
ADD_FUEL's Avatar
Default Re: crx wire harness help? (punkdown)
oh ok i see, i appreciate the help man thnx
Old Jun 20, 2008 | 11:47 AM
streetjdmrex's Avatar
or u can go to rywire.com and they can modify your crx si harness into a obd1 vtec harness that plugs right in and work with the rest of your car without u having 2 do the harness urself and buyin the dizzy jumper harness, and ecu jumper harness check it out heres the link http://rywire.com/store/8891-c...abcb0
Modified by streetjdmrex at 3:52 PM 6/20/2008
Emoney97ss
Jun 16, 2011 03:33 PM
ikaika3269
10
Feb 26, 2008 06:25 PM
jarel
Nov 3, 2004 03:31 PM
91teg
Sep 1, 2004 06:06 PM
CLICC916
Aug 13, 2003 05:43 PM
