Sagging 5thgen front bumper
Old Jun 11, 2008 | 05:26 AM
LukieLuc's Avatar
Default Sagging 5thgen front bumper
Hey guys
I got a 5th gen a few days ago and I'm going to be putting it on the road today.
Its front bumper has a slight sag which is noticeable where the bumper meets the fender near the headlights. I haven't tried to take off the bumper yet but I was wondering how do I fix it?
Thanks in advance
Old Jun 11, 2008 | 05:59 AM
DfwBB6's Avatar
Default Re: Sagging 5thgen front bumper (LukieLuc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys
Thanks in advance</TD></TR></TABLE>
maybe this will help http://forums.ntpog.org/showthread.php?t=14
Old Jun 11, 2008 | 09:26 AM
LukieLuc's Avatar
Default Re: Sagging 5thgen front bumper (DfwBB6)
my clips arent broken they are there, it just saggs
Do you guys think i can bend the clip upward so it can sit flush to the fender?
Old Jun 11, 2008 | 09:49 AM
'95 BA8's Avatar
Just age I'm thinking?
Gravity starts to work on it?
Try zip ties to pull it back up.
I know a lot of fifth gens have this problem.
Old Jun 11, 2008 | 10:00 AM
LukieLuc's Avatar
Default Re: Sagging 5thgen front bumper ('95 BA8)
Is it the clips them selves that are worn or the metal which the clips are screwed on to?
Old Jun 11, 2008 | 10:10 AM
'95 BA8's Avatar
I'm not really sure, a member on this forum got a new bumper from a friend's crashed Prelude, he said that fixed the problem. So I'm thinking it's the bumper itself that gets worn and the plastic loosens up. I don't think the metal onto which they are screwed would wear out like that.
But don't quote me on that.
Old Jun 11, 2008 | 10:39 AM
98vtec's Avatar
moderator emeritus
if you are interested, i am working with rosko in getting a prototype of the SSR bumper release fittings remade.
Old Jun 11, 2008 | 11:41 AM
DfwBB6's Avatar
Default Re: Sagging 5thgen front bumper (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">if you are interested, i am working with rosko in getting a prototype of the SSR bumper release fittings remade.</TD></TR></TABLE>
kewl im in let me know
Old Jun 17, 2008 | 03:35 PM
LukieLuc's Avatar
can anyone give me tips on how to remove the 5 clips on the top of the front bumper?
Old Jun 17, 2008 | 04:23 PM
LukieLuc's Avatar
what can i use to remove them without breaking or damaging them
Old Jun 17, 2008 | 06:11 PM
LukieLuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">can anyone give me tips on how to remove the 5 clips on the top of the front bumper?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">what can i use to remove them without breaking or damaging them </TD></TR></TABLE>
these clips, come on guys anyone?
Old Jun 17, 2008 | 06:28 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DfwBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
maybe this will help http://forums.ntpog.org/showthread.php?t=14</TD></TR></TABLE>
Thanks.
these clips, come on guys anyone? </TD></TR></TABLE>
A small screwdriver works fine for me.
Old Jun 17, 2008 | 06:33 PM
LukieLuc's Avatar
Default Re: Sagging 5thgen front bumper (mkazm83)
they wont come out i tried that
anyone else???
Old Jun 17, 2008 | 06:53 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">they wont come out i tried that
anyone else???</TD></TR></TABLE>
Which part of the clip are you trying to break free? There are two parts to it, a head, and then the clip. You're supposed to loosen the head which will pop up, thus releasing the clip.
Old Jun 17, 2008 | 07:09 PM
russlan44's Avatar
the plastic clips right, do they just spin and spin, if that dont put that much preasure and hold the outside of the clip so it wont spin while ur trying to unscrew it.
Old Jun 17, 2008 | 07:12 PM
mkazm83's Avatar
Default Re: Sagging 5thgen front bumper (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">the plastic clips right, do they just spin and spin, if that dont put that much preasure and hold the outside of the clip so it wont spin while ur trying to unscrew it.</TD></TR></TABLE>
The clip does not screw in, it pressed into the hole, and is held in place with the head of the clip locked in.
Old Jun 18, 2008 | 06:19 AM
LukieLuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">
The clip does not screw in, it pressed into the hole, and is held in place with the head of the clip locked in. </TD></TR></TABLE>
Right so how can I remove them without damaging or breaking them?
Old Jun 18, 2008 | 08:41 AM
mkazm83's Avatar
Stick a small screwdriver into the slot on the clip, and wiggle it till it makes its way under the "head". Then twist the screwdriver slowly and it will pop up. If it breaks, that means the plastic is old and brittle and there is no way around breaking it.
Old Jun 18, 2008 | 06:33 PM
ethereal2pt2's Avatar
i took off the rebar and added washers to the bottom two bolts that hold up the rebar. this forces the rebar to angle up thus forcing the bumper to sit higher. i have never suffered from bumper sag as my bumper sits flush with the fender. i'll try and snag a pic later.
Old Jun 18, 2008 | 06:38 PM
LukieLuc's Avatar
Default Re: Sagging 5thgen front bumper (ethereal2pt2)
what do you mean by rebar? the support where the 5 clips are on top of the bumper?
crip
Aug 17, 2010 04:42 PM
JDM23
Aug 13, 2007 11:45 AM
walek
Honda Civic (2006 - 2015)
Jan 21, 2007 07:15 PM
es_squared
Feb 10, 2004 03:21 AM
