Can i keep the rocker assembly on when using this valve spring compressor? And steam seals
Going to install some new valve springs in my b16a
plan to keep the head on and use a compressor like this one:
i am a noob
but can the rocker assembly be left on.. maybe just swung vertically to get some space?
could i replace the valve stem seals too with the rockers in place as well?
(i dont want to remove the rockers and the the rod etc etc, want to do it as easy as possible)
i am a noob
Should be able to have access to the valve stems and everything. You will have limited room but still have enough room to take them out. You can take out the rocker rails and take the rockers out if you don't have enough room. Cool little tool. How much are one of those things.
sauceja
Feb 24, 2006 07:46 PM
ltho1998
Aug 3, 2003 05:45 PM
