Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
gasoline in engine
Old Jun 11, 2008 | 12:46 AM
hmongshaa's Avatar
Default gasoline in engine
my 01 civic ex cylinder head is flooded with gasoline. i was wondering if anyone knew how to deflood it? any help well be great.
Old Jun 11, 2008 | 04:07 AM
JimmyM86's Avatar
Default Re: gasoline in engine (hmongshaa)
If you restrict the fuel injectors from pulsing, and your spark plugs from sparking, cranking your engine over should purge out some of the gas. But I would presume this would cause a CEL to come on (FI and misfire codes)
Are you not getting spark? Letting the car sit for a while should allow the fumes to die down to allow you to start the car and burn off the rest...I would try letting it sit first.
Old Jun 11, 2008 | 01:45 PM
rudeSPEC's Avatar
you should probably be more concerned with why gasoline is pooling in your motor, purging it out isnt gunna fix it, however depending how long gas sat inside your motor, your probably gunna wanna do an oil change or something cause gasoline has a nasty habit of flaking bearings
Old Jun 11, 2008 | 01:49 PM
oddmut's Avatar
Default Re: (rudeSPEC)
let your engine sit. it should deflood. and you're good to go again.
Old Jun 11, 2008 | 02:44 PM
Curiouz_G's Avatar
maybe its because ive lost all hope in HT but when i saw this title, i almost cried.
xW01FxGANGx
Jun 29, 2014 08:46 AM
rickdell
Apr 22, 2008 07:00 PM
bgx9ner
May 6, 2007 04:54 PM
400whp
Feb 11, 2004 01:52 PM
