Question for timing on a 93 accord
Old Jun 10, 2008 | 11:58 PM
a1320honda's Avatar
Default Question for timing on a 93 accord
So heres the scenario.
Picke up a 93 accord LX from work for a daily, and it was running just fine. i took it to the car wash to clean up under the hood and half way through a light spray down it starts running like crap. I tried to drive off and was doin ok, but with a slight miss, but got it under a hard load and it died and now wont restart. Its getting spark and fuel and the compression gauge is showing 180 across the board. So im wondering if it might have just jumped a tooth or if something electronic got wet. My question is, if i pull the valve cover and line up the mark on the cam, can i use the timing marks on the flywheel to see if it jumped time, or do i need to tear it all the way apart? Im gonna let it dry over night and while im at work.
Old Jun 11, 2008 | 12:49 AM
badboyr66's Avatar
Default Re: Question for timing on a 93 accord (a1320honda)
Pull the dizzy cap and let it dry
Old Jun 11, 2008 | 05:26 AM
a1320honda's Avatar
Default Re: Question for timing on a 93 accord (badboyr66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badboyr66 &raquo;</TD></TR><TR><TD CLASS="quote">Pull the dizzy cap and let it dry </TD></TR></TABLE>
Pulled the cap and it was bone dry. checked spark on all 4 and their all getting spark.
Old Jun 13, 2008 | 04:32 AM
Maachan513's Avatar
You can try lining up timing mark on the cam pulley to the head and check the TDC mark on the flyweel.
bandjstone
Oct 11, 2012 10:57 PM
istabrak
Oct 28, 2009 04:09 PM
bnuts59
Jun 12, 2008 06:01 PM
Southloop
Sep 24, 2007 03:16 PM
