4-1 header or 4-2-1 ?
Old Jun 10, 2008 | 06:27 PM
Teg LS's Avatar
Default 4-1 header or 4-2-1 ?
hey im just wondering if there is any advantage to either of these, or if they're pretty much the same, and what you think would be best for my '00 LS
Old Jun 10, 2008 | 06:34 PM
Tegraracer90's Avatar
Default Re: 4-1 header or 4-2-1 ? (Teg LS)
correct me anyone if i am wrong but i have heard that the 4-1 header makes better top end power..but its lower under the car which makes them subject to bottoming out in bumps speed humps etc...but the 4-2-1 sits closer to the bottom of the car much like the stock manifold...
Old Jun 10, 2008 | 06:38 PM
Teg LS's Avatar
Default Re: 4-1 header or 4-2-1 ? (Tegraracer90)
so does the 4-2-1 make better low end power or are they about the same? and if i got a 4-1 id just be weary of bumps then... i could do that
Old Jun 10, 2008 | 06:54 PM
XslickwhitetegX's Avatar
I know some people that can't run a 4-1 header cuz their car is slammed so much, they half to run 421..
In all honesty tegs are slow so putting on a 421 or 41 header wont make a big effect on the power gains... that's w/ aftermarket exhaust on of course.
Old Jun 10, 2008 | 07:05 PM
jakeiscool's Avatar
Banned
in all honesty its an ls, wont make much of a difference. i would disregard what these people are telling you as most of them are just reitterating the rumors and hearsay from past posts.
both will most likely yield the same hp gains just in different areas of the powerband, 4-1 being higher in the rpm range but probably not super noticeable on an ls. just go for whatever is cheap that you can find.
Old Jun 11, 2008 | 09:35 AM
Teg LS's Avatar
Default Re: 4-1 header or 4-2-1 ? (jakeiscool)
this helps a lot thanks
Old Jun 11, 2008 | 10:05 AM
St. Jimmy's Avatar
* B A N N E D *
https://honda-tech.com/zerothread/2102570
Thats one of the best all around headers for the price. Its a little spendy but you get what you pay for.
Old Jun 11, 2008 | 11:38 AM
super jdm yo's Avatar
Default Re: 4-1 header or 4-2-1 ? (St. Jimmy)
yeah for an ls there really wouldn't be a point in a 4-1 just because ls' aren't really in the high rpm range anyways.
Old Jun 11, 2008 | 11:53 AM
NAmodified's Avatar
Default Re: 4-1 header or 4-2-1 ? (super jdm yo)
id buy the 4-1. or u can save and go turbo. you wont regret it.
Old Jun 11, 2008 | 08:29 PM
Teg LS's Avatar
Default Re: 4-1 header or 4-2-1 ? (NAmodified)
i fail to see how i mentioned anyhting about a turbo.... but why do you say 4-1? cause it looks cool? cause im thinking a 4-2-1 would be best now
Old Jun 11, 2008 | 08:35 PM
ishnathan's Avatar
ya 4-1 headers are better for high rpm and not so good for low but anyways 4-1 is great for v-tech not so sure about an ls but if you decide to go ls v-tec get 4-1
Old Jun 11, 2008 | 08:54 PM
ivan93egreppin210's Avatar
Default Re: 4-1 header or 4-2-1 ? (ishnathan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ishnathan &raquo;</TD></TR><TR><TD CLASS="quote">ya 4-1 headers are better for high rpm and not so good for low but anyways 4-1 is great for v-tech not so sure about an ls but if you decide to go ls v-tec get 4-1</TD></TR></TABLE>
is that right? care to explain or pehaps show us your dyno from when you compared headers. also the fact that you cant spell vtec really hurts your credibility.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg LS &raquo;</TD></TR><TR><TD CLASS="quote"> what you think would be best for my '00 LS</TD></TR></TABLE>
i think you should worry less about the header and get a vtec tranny if you dont have one already. that should be you first and most important mod. pick your header according to future build plans and not "which header will give me 2 more hp for 500 rpm at 6800 rpm where im most likely not making power on my stock motor".
Old Jun 11, 2008 | 09:03 PM
Teg LS's Avatar
Default Re: 4-1 header or 4-2-1 ? (ivan93egreppin210)
im not really planning on going ls vtec though because i have an auto, i was just wondering if there was a significant difference between the two headers
Old Jun 11, 2008 | 09:16 PM
ishnathan's Avatar
look up 4-1 vs 4-2-1 headers for dyno results and you'll see the results oh and this guy under of me got me with the vtech but its alright im not focused at the moment but before you talk look at what you type your self before talking you dont even have the right grammer...........that should be you first and most important mod.
you should go for 4-2-1 for your auto
Old Jun 12, 2008 | 12:57 AM
Dark@Powers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ishnathan &raquo;</TD></TR><TR><TD CLASS="quote">grammer...........that should be you first and most important mod.</TD></TR></TABLE>
Did I miss the joke?? because grammer is spelled "ar" not "er" and "you" can not be interchanged with "your"......
Old Jun 12, 2008 | 01:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivan93egreppin210 &raquo;</TD></TR><TR><TD CLASS="quote">
is that right? care to explain or pehaps show us your dyno from when you compared headers. also the fact that you cant spell vtec really hurts your credibility. </TD></TR></TABLE>
In THEORY , 4-1 headers WILL make more power at higher RPMs with a sacrifice of midrange, compared to 4-2-1 headers that make more Midrange powers with a sacrifice at higher RPMs. 4-1 headers WILL also have peak torque occuring at higher RPMs when compared to a 4-2-1. Or so this is the theory we have all come to learn right? Keep in mind tho, this is in THEORY..... how much of a difference the header layout will actually display on a dyno is negligible on a stock car. As for a built car, I have not seen a comparison between the two headers, of the same company (to keep the variables at a minimum), to warrant a conclusion, so I'll keep my mouth shut on that.
As you might hear, this idea has become obsolete, NOT contradicted, with the introduction of the Tri-Y header, which provided the long tubes of 4-1 headers with a 4-2-1 layout.
Old Jun 12, 2008 | 09:11 AM
i never said you were wrong and didnt mean to be an *** but there is too much unproven "facts" being tossed around here on h-t. this dude will never know for sure unless he can view dyno slips compairing the two. here is a good link supporting your claim.the fact that he is auto and not mt suggests he should get a try-y for more mid range since he wont be in that rpm range for long.
http://www.hondatuningmagazine....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ishnathan &raquo;</TD></TR><TR><TD CLASS="quote">look up 4-1 vs 4-2-1 headers for dyno results and you'll see the results oh and this guy under of me got me with the vtech but its alright im not focused at the moment but before you talk look at what you type your self before talking you dont even have the right grammer...........that should be you first and most important mod.
you should go for 4-2-1 for your auto </TD></TR></TABLE>
thats one mighty long sentence you got there dude. lol im sorry but i had to. ok ill stop before we lock this dudes thread.
Old Jun 12, 2008 | 09:05 PM
Teg LS's Avatar
thanks for this site, it helped me a lot in deciding, also a key factor is installation as well, so its good to know the tri-y is in 2 pieces which would make it a hella lot easier to install
Old Jun 14, 2008 | 08:45 AM
no problem man. good luck
Old Jun 14, 2008 | 05:46 PM
rebo0t's Avatar
Old Jun 14, 2008 | 06:04 PM
TurbdEG6's Avatar
Default Re: (rebo0t)
this was covered in a recent issue of Honda Tuning. I don't completely remember the motor that was used...i believe it was an itr motor. the 4-1 yielded higher max power and torque, but mostly in high RPMs. the tri-y made more low and midrange power/torque but failed to at least tie the 4-1 by 2-3 hp and i don't remember the torque figures.
Old Jun 14, 2008 | 07:05 PM
EpicKills's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jakeiscool &raquo;</TD></TR><TR><TD CLASS="quote">in all honesty its an ls, wont make much of a difference. i would disregard what these people are telling you as most of them are just reitterating the rumors and hearsay from past posts.
both will most likely yield the same hp gains just in different areas of the powerband, 4-1 being higher in the rpm range but probably not super noticeable on an ls. just go for whatever is cheap that you can find.</TD></TR></TABLE>
bahahahaha, I love how he bashed on you all then repeated what you said. hahaha some people... we need an eye rolling smiley.... ::me rolling my eyes::
Old Jun 14, 2008 | 10:52 PM
iluvmyda's Avatar
go 4 2 1 no cutting,no scrubbing,no 2.5 *** 2.5!
Old Jun 14, 2008 | 11:16 PM
Default Re: 4-1 header or 4-2-1 ? (iluvmyda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmyda &raquo;</TD></TR><TR><TD CLASS="quote">go 4 2 1 no cutting,no scrubbing,no 2.5 *** 2.5!</TD></TR></TABLE>
no 2.5?
Old Jun 15, 2008 | 12:43 AM
Adambomb's Avatar
He means a 2.5" outlet, where your exhaust hooks up.
But I'm personally going with a 4-1 header rather than a 4-2-1, because I've heard that 4-2-1 have a tendency to leak sometimes, because of the way they're designed. But then again, it is hearsay.
