GSR v LS swap MPG in EG / EK chassis?
To get a rough base line, I looked at what these motors get in the considerably heavier Integra chassis.
I'm curious how the MPG is improved in the EG / EK chassis? ( minus 200-800lbs depending )
Anyone with these swaps running well chime in here? Or someone just with knowledge in this area.
I have zero knowledge of B series; however, i did just swap in a single v-tec in my civic vx. Before the swap i was getting around 30 mpg with the d15z1 and a y8 tranny. I am now currently running a d15b with the same(failing) y8 tranny. I had my ECU tuned on a wideband o2 sensor, and im getting the same milage 30-35 depending on how i drive it.
So my advice to you is do the swap you want then get it tuned (wideband o2, not a regular o2). I had my ECU tuned for WOT( advanced the **** out of the timing and fuel) and partial throttle(leaned out the timing and fuel). I have the best of both worlds Its a bad *** single v-tec when i step on the gas, and a wussy econo car when im not stepping on the gas.
edit* also an engine will get better gas millage when its in a lighter car.
DatSlammedek4
17
Aug 15, 2013 05:34 PM
SHO-NUFF
Jun 26, 2008 03:05 PM
IheartSpoon
Aug 29, 2002 07:44 PM
