another PITA CKF CRANK sensor problem
sooooo here we go again, I have searched and read all those ckf sensor post and no one has reply back to them to get a good answer
ok first off, all I need to know is, WHERE DO I HOT WIRE HOOK UP THE CKF SENSOR ONTO THE ECU PIN PLUGS?? that's it...thank you.
(((( ok first off, all I need to know is, WHERE DO I HOT WIRE HOOK UP THE CKF SENSOR ONTO THE ECU PIN PLUGS?? that's it...thank you.
