running rich??? please real fast
i have a 96 four door and when it warms up it idles around 100 rpms for the most part, every once and a while it will go to 7-800 it will even sometimes die at idle, no cel, do you think i can advance the timing (toward firewall) to help this problem? thanks alot
Modified by 4doorek96 at 9:05 PM 6/10/2008
Good advice is hard to come by. From what i can tell a couple of things could be wrong. Your ignition timing needs to be set, and your idle needs to be set. If thus doesn't help your IACV needs to be cleaned or maybe replaced. Other then that you shouldn't have any problems.
REDBARON
Oct 4, 2001 07:40 PM
