Cam gears necessary after milling the head?
Old Jul 17, 2002 | 05:40 AM
Edwin's Avatar
Default Cam gears necessary after milling the head?
Are cam gears necessary after milling the head?
Old Jul 17, 2002 | 05:45 AM
MackSpeed-616's Avatar
Default Re: Cam gears necessary after milling the head? (Edwin)
only if you want to re-zero the cams.
Old Jul 17, 2002 | 05:49 AM
Edwin's Avatar
Default Re: Cam gears necessary after milling the head? (BustaNutt-616)
Heard that timing has to be increased after milling a head.
Would you advance timing via the distributor or through camgears?
Old Jul 17, 2002 | 05:55 AM
JPP's Avatar
JPP
Yep both camshafts timing will be retarded by a few degrees.
Bustanut: Are you looking for flaming with that sig. V-tech is a big no no on H-T
Old Jul 17, 2002 | 05:58 AM
JPP's Avatar
JPP
First readjust the camshaft timing with the camgears and then readjsut the ignition timing with the distributor and a timing light. Every time you play with the intake camshaft you should readjust the ingniton timing. You should do this on a dyno for optimal performance.
[Modified by JPP, 10:00 AM 7/17/2002]
all-mtr-teg
17
Aug 26, 2007 07:45 PM
gATOr65
Dec 27, 2005 02:03 PM
DcWest
Sep 27, 2005 12:49 PM
scUba-stEve
13
May 15, 2005 08:47 PM
