H22a Thrust washer clearance
Old Jun 10, 2008 | 03:58 PM
turbo_d's Avatar
Default H22a Thrust washer clearance
Just need to know what the clearance is for h22a thrust bearings. I measured it with a dial and indicator, and it measured .006, and I could feel it moving a tiny bit from side to side. If the motor is going to be revd up to 8k that thing is going to fall apart. I just need to know the right specs for the trust bearings. I think its .008. Am I correct???? thanks, David
Old Jun 10, 2008 | 05:52 PM
turbo_d's Avatar
Default Re: H22a Thrust washer clearance (turbo_d)
bump
Old Jun 10, 2008 | 07:07 PM
turbo_d's Avatar
Come on!! Some one has to know this crap. I just dont have a freakin service manual!!! bump
Old Jun 10, 2008 | 08:00 PM
Giant_Bean's Avatar
I didn't find thickness measurements for the thrust washer, but crankshaft end play should be no more than .45mm, and ideally between .10mm and .35mm. Hope that helps
Old Jun 10, 2008 | 08:12 PM
vinuneuro's Avatar
Doing this kind of work without a service manual is asking for a lot of trouble.
Crankshaft end play:
Standard/new: .10-.35mm (.004-.014in)
Service Limit: .45mm (.018in)
oldskoolchris
16
May 30, 2019 11:34 PM
ninefour_cd5
Jun 8, 2014 03:42 PM
slowboy90
Jan 28, 2010 06:46 PM
CiViC SiR
Jun 2, 2003 12:43 AM
