Built Allmotor B18B w/ CTR Pistons.
For sale is a ready to race built b18b ls acura integra block. i put 600 miles on this and then bought a new car so i decided to part the whole thing. there is nothing wrong with it. its has good compression and no blow by or oil consumption. this block is equipted with oem standard bore civic type r pistons. the ls rods were machined and balanced to fit, arp rod bolts. It has acl bearings, new waterpump, new integra type r oil pump, all new seals every where, new timing belt. I had CNT Machine of orem utah balance and blue print the entire rotating assembly. they balanced it to my 12 lb act flywheel. that's not included in this auction but its for reference to the balance. I also had them dingle hone it before TURBO LABORATORIES or Orem utah assemble it. I also had the machine shop hot tank and deck the head so that the head and block would mate as good as b series engines do. You will be very impressed with this block, it made excellent power. motor never smoked. you will receive what you see in the pictures, the 2 golden eagle head studs sticking out will not be included. I had this motor built from the stock ls version that was not blown or damaged. i pulled the good ls head off and put the vtec head on so the head stud holes have only been torqued twice in its life. please feel free to ask any questions. thanks for looking.
$600.
Modified by shivic at 12:48 PM 6/16/2008
Modified by shivic at 2:19 PM 6/17/2008
$600.
