Stock '90 CRX Si throttle body Q's
Old Jun 10, 2008 | 02:13 PM
4crx4me's Avatar
Default Stock '90 CRX Si throttle body Q's
Is anyone familiar with repairing or rebuilding a stock A6 TB? Or can someone recommend a place beside a j/y for a replacement?
I have a couple that leak coolant and one that has a sticky butterfly.
Does anyone sell a rebuild kit? Or maybe one already rebuilt, if kits aren't available?
Old Jun 11, 2008 | 12:54 PM
4crx4me's Avatar
Default Re: Stock '90 CRX Si throttle body Q's (4crx4me)
ttt
Old Jun 11, 2008 | 02:26 PM
skellator_thoj's Avatar
i've rebuilt some honda and dsm tbs by taking out the valve and cleaning it and going to the hardware store to buy the same exact o rings and put it back.. seems to work good
Old Jun 11, 2008 | 02:32 PM
4crx4me's Avatar
Default Re: Stock '90 CRX Si throttle body Q's (skellator_thoj)
Thanks for the reply. I'll try it.
Did you try replacing the return spring with another? Or replacing the shaft bushings at all?
I'm curious to see if those things need to be replaced, or if cleaning everything up real good will solve my sticky throttle problems.
Old Jun 11, 2008 | 05:54 PM
4crx4me's Avatar
Well I found my older leaking, no longer used, tbs and neither one of them stick! And they look to be in much better shape than the pos tb on there now.
So, I'm either going to try to JB weld them or I just bypass the cooling hoses altogether.
Old Jun 15, 2008 | 03:10 PM
4crx4me's Avatar
All is well with the Si once again.
Put the old TB back on, bypassed the leaky coolant lines that run through the bottom of the TB. I'm a happy camper, NO More sticky throttle!!!!!!
Now I just need to charge the A/C, and a few other minor things and we'll be good to go once again.
stevescivic
Nov 18, 2004 02:19 PM
skybleedsblk
Aug 23, 2004 08:55 PM
fishin9975
Jun 14, 2004 06:05 AM
